Cutout in manifold of Super A
Les Ball
02-18-2006 05:51:32
I have a Super A in which there is a rectangular cutout in the exhaust side of the manifold, of about 1" x 3". Would anyone have any idea as to why this would have been done ? Thank you for your help.
gene bender
02-19-2006 19:15:38
 Re: Cutout in manifold of Super A in reply to Les Ball, 02-18-2006 05:51:32
Your tractor was probably a dual fuel engine and thats the way the manifold was. Do you have the plate that bolts on and then the muffler goes on top. Your hood probably has four holes also. Is the shield still on the manifold just above the carb? Do you need the correct pipe assy to bolt to the manifold?
Les Ball
02-18-2006 20:39:26
Thank you all for the ideas. I have been to a ballgame, and just got back. I will try to take a pic of it tomorrow and post it for your further analysis. Thank you all !!
Janicholson
02-18-2006 11:00:57
Is the hole directly into the exhaust ports?
where on the manifold is the hole? What is the serial number and suffex (if any)?
It is possible someone was making a repair and didn't finish.
Pictures would be great.
JimN
Les Ball
02-19-2006 08:49:30
 Re: Cutout in manifold of Super A in reply to Janicholson, 02-18-2006 11:00:57
can you describe to me how to attach my digital photo ?
Shaggy
02-18-2006 08:28:31
Didn't the kerosene Manifolds have a rectangular hole on the top where the pipe bolts on?
Hendrik
02-18-2006 12:47:11
 Re: Cutout in manifold of Super A in reply to Shaggy, 02-18-2006 08:28:31
Yes, the manifold has a flat surface on top, onto which the top end that narrows into the pipe is bolted. I could send a digital photo of my dual fuel manifold. My e-mail is open.
Hugh MacKay
02-18-2006 08:01:34
Les: Rather odd, I must agree with Turk, however a true Super A would have hydraulics. Someone must have been doing some parts exchange.
Turk
02-18-2006 07:13:45
It is probably for a pnuematic lift system.
