966
T.L. IH
02-18-2006 20:52:14
looking at a 966 that the power take off slips when in a load. It makes some noise. what would be problem.
the tractor vet
02-19-2006 05:55:13
 Re: 966 in reply to T.L. IH, 02-18-2006 20:52:14
It could be that the clutch pack is shot and pressure is low on the adjustment ( takes special fitting to check pressure ) Or it could be that the splines on the input shaft are going out to lunch and that will require a new clutch pressure plate and PTO input and bearing and seals and a split. Since i can not check it out myself it could be a minor problem of pulling the PTO unit out and throwen in a new set of clutches and setting the pressure up to a split and a main clutch job. OR both .
GFordoSD
02-19-2006 07:29:52
 Re: 966 in reply to the tractor vet, 02-19-2006 05:55:13
The PTO shaft on my 966 rotaes very slowly when it is NOT selected to engage. If you grasp it very lightly with your hand you can stop it. Can I adjust something to get it to stop completely?
Gordo
Aces
02-19-2006 10:20:50
 Re: 966 in reply to GFordoSD, 02-19-2006 07:29:52
GfordoSD No the brakes are spring loaded and pressure leased, so trhe pads must be bad.
