wr-9 tire size
jdacih
02-19-2006 21:10:44
Ive got a 1950 Mccormick WR-9 on propane with 15x34 tires on it, they are pretty bad and I wondered if 18.4x34 tires would fit it and clear the fenders? thanks.
Roger in Iowa
02-20-2006 14:08:49
 Re: wr-9 tire size in reply to jdacih, 02-19-2006 21:10:44
Go with the 18.4 x 34 as that is the replacement for 15 x 34. Don't forget, to be correct for a WR-9 you need the rice version of tire.
My tractor is shown in tractor photos. Search for rice. My name is listed after the description.
Roger Russ in Iowa
sw6 joel
02-20-2006 05:29:25
anyone happen to know what tire size came original on a 1952 super w6 gas?
Thanks
Harold H
02-20-2006 06:59:57
 Re: wr-9 tire size in reply to sw6 joel, 02-20-2006 05:29:25
The 1952 W-6 was standard with 14 x 30 (16.9 x 30). Factory options were; 13 x 30 (15.5 x 30) and 15 x 30 (18.4 x 30). I imagine the Super W-6 had the same sizes but I don't have those original specs.
Harold H
Harold H
02-20-2006 05:17:54
It will fit fine. 18.4 x 34 is the modern size for the old 15 x 34 tire size designation. The original rear tire sizes available from the factory on the WR-9 were: 14 x 34 (16.9 x 34), 15 x 34 (18.4 x 34), and 18 x 26 (23.1 x 26).
Harold H
4444
02-20-2006 17:09:05
 Re: wr-9 tire size in reply to Harold H, 02-20-2006 05:17:54
I've got 2 WR9s and one has 18.4x34 and the other has 23x26
tobaccoman
02-20-2006 03:41:42
I recently replaced the rear tires on my WR-9 with 16.9 x 34 and they worked fine. I didn't want to try 18.4's with the big fenders, but that is what came on my W-9.
If you decide to go w/ 18.4's, let us know how it worked out. Good luck.
tobaccoman
