450 transmission oil
rr_67401
02-21-2006 10:07:11
my 450 is pewcking transmision fluid out of the air breather on the pto cover. it is foamy looking and green in color. I take the plug off the side of the tranny and it just boils out, any ideas????
Nat 2
02-21-2006 12:59:47
 Re: 450 transmission oil in reply to rr_67401, 02-21-2006 10:07:11
1. Park the tractor indoors, or at least buy a decent tarp to cover it up, for Pete's sake!
2. Change the transmission fluid. All that sitting outdoors, the rear end is full of water.
I must admit that is the most interesting spelling of "puking" that I have ever seen :)
the tractor vet
02-21-2006 11:35:37
Two things (1) you are over full with water and it need to be drained and refilled with Hy Tran (2) you ft. PTO seal is shot and need to be replaced.
rr_67401
02-22-2006 08:38:06
 Re: 450 transmission oil in reply to the tractor vet, 02-21-2006 11:35:37
thanks for the help. An ih dealer thought I had air leaking in the case. I drained quite a bit of water out. I will add fresh Hy Tran. thanks again..... .
