tachometer of Farmall 340
Larry Hardesty
02-23-2006 17:17:19
The tachometer on my Farmall 340 quit working. Seems to me the problem is in the gear assembly for the tachometer drive. If I put an electric drill on the tach cable, the tachometer runs fine. I connect the cable to the tach drive near the distributor, and the tach will work for awhile and then stop. Seems like the cable is not connecting to something or a gear is stripped or something in the drive. Anyone have any experience with this? Also, if parts needed are available Case IH.
J. J. from Afton
02-24-2006 16:44:49
 Re: tachometer of Farmall 340 in reply to Larry Hardesty, 02-23-2006 17:17:19
The cable and gear were readily availible at a CaseIH dealership for me. Luckily I didnt have to replace the gear housing piece like i originally thought, because they could only find one, over in central Wisconsin, which was $150 plus shipping.
I guess if you cant find the gear, have someone else check their dealership or parts store or have someone machine one for you.
Larry Hardesty
02-24-2006 16:52:40
 Re: tachometer of Farmall 340 in reply to J. J. from Afton, 02-24-2006 16:44:49
The local dealer said they were not available, but I got on the Internet and got one from a dealer in Wisconsin. Even just the plasitic gears as $50. Glad that I could get one for a 40+ year old tractor
Thanks
J. J. from Afton
02-24-2006 16:55:27
 Re: tachometer of Farmall 340 in reply to Larry Hardesty, 02-24-2006 16:52:40
Yah they are an expesive little gear.
Janicholson
02-24-2006 06:57:41
The cable end could be turning in the gear. If the gear looks good on disassembly, replacing the core (with an automotive spedo cable --cheep--)can work well.
JimN
Tweeter
02-24-2006 07:56:29
 Re: tachometer of Farmall 340 in reply to Janicholson, 02-24-2006 06:57:41
Can an electric tach replace the original?
http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=127689&query=retrieval
Janicholson
02-24-2006 11:52:47
 Re: tachometer of Farmall 340 in reply to Tweeter, 02-24-2006 07:56:29
Sure, Sun SuperTach will fit the hole (last on I did anyway) just follow the directions, It will not please the originality police. I always seal the edge of the glass with clear Lexcel Acrylic sealant to prevent water entry.
JimN
Larry Hardesty
02-24-2006 12:21:06
 Re: tachometer of Farmall 340 in reply to Janicholson, 02-24-2006 11:52:47
The gear assembly has 3-4 teeth missing. I tried to get a replacement at the local Case IH dealer (Part # 369 695 R91) but they said not available. Any ideas as to where to look, if a machine shop could make one out of plastic, or if any way to repair it. Any help appreciated.
Thanks
Larry
Larry Hardesty
02-24-2006 11:52:11
Don't know what would be involved. I just checked with the local Case-IH dealer and the gear assembly (369 695 R91) and the entire package (369 694 R91)neither one are not available. I wonder if a machine shop could make one out of plastic (since it is a plastic gear) without a huge expense??
Janicholson
02-24-2006 12:24:54
 Re: tachometer of Farmall 340 in reply to Larry Hardesty, 02-24-2006 11:52:11
I would guess that the gear could be found (or duplicated by a competant spedo shop. Annother place might be a good transmission rebuilder They have Spedo gear systems to assist customers with dramatic gauge issues!
JimN
Larry Hardesty
02-24-2006 16:54:54
 Re: tachometer of Farmall 340 in reply to Janicholson, 02-24-2006 12:24:54
Found one at a dealer in Wisconsin. Not cheap ($50+) but glad to get one for a 40+ year old tractor.
Thanks
Larry
J. J. from Afton
02-23-2006 17:39:13
My dad had the same problem on his 340 utility, the gear had gotten stuck and stripped out so all we did was replace the gear and cable, which we got at CaseIH, they are availible, but expensive. The gear and cable cost about $50 each.
Larry Hardesty
02-23-2006 18:29:38
 Re: tachometer of Farmall 340 in reply to J. J. from Afton, 02-23-2006 17:39:13
Thanks, It might have stripped one very cold day with the I started the tractor. I suppose the grease/oil in there could have been pretty solid. Only thing I can figure anyway. I have not taken it apart to see if the gear is stripped. Maybe I need to do something to clean 40+ years of old oil/grease out of there.
Thanks
Larry
K.B.-826
02-23-2006 19:50:34
 Re: tachometer of Farmall 340 in reply to Larry Hardesty, 02-23-2006 18:29:38
It's very common for that tach drive to strip out. Made of plastic.
Larry Hardesty
02-24-2006 12:18:20
 Re: tachometer of Farmall 340 in reply to K.B.-826, 02-23-2006 19:50:34
I tried to get the part 369 695 R91 at the location Case IH dealer. No luck. Any ideas where I can get the gear assembly for the tachometer drive for the Farmall 340.
Thanks
Larry Hardest
02-24-2006 08:24:19
Thanks for the information. Now to try to get the gear drive apart and get the piece out!!
Larrh
