Farmall 460 ta/ clutch problem
t.ry.
02-23-2006 17:59:29
somethings going on it the ta. The main clutch works. But when in gear push clutch in and stop go to put in reverse or another forward gear it won't come out of gear unless pull very hard. the t'a lever doesnot operate at all. when you move ta lever forward or backward. I always worked before and went to plow snow this winter and all the sudden had this problem. thanks any advice would help.
Ted in NE
02-23-2006 20:10:31
 Re: Farmall 460 ta/ clutch problem in reply to t.ry., 02-23-2006 17:59:29
Remove the small cover on top of the TA houseing. pull the TA lever back & see if the linkage is working the TA clutch press plate fingers, if so usually the nut that retains the TA clutch to the Planetary carrier has came loose and backed out against the TA clutch disc. Will take a split at the clutch houseing to repair.
K.B.-826
02-23-2006 19:47:45
Sounds like your TA clutch is not disengaging. Try adjusting the linkage first, but I'd almost suspect that your TA clutch is stuck or possibly the sun gears or planet gears are messed up and turning as a unit even with the TA clutch disengaged.
jossette
02-23-2006 18:55:00
If you have correctly adjusted the clutch and t/a, It is time for a clutch.. pulling the t/a back should help in shifting.
t.r.y.
02-24-2006 02:25:05
 Re: Farmall 460 ta/ clutch problem in reply to jossette, 02-23-2006 18:55:00
Hey guys once again I appreciate the help. I new it was someting interenal in the ta. Just figured I would ask around first. Not quite sure the tractors worth a clutch and ta job but Useing the way it is will end up ruining slides and shifter forks, and gears I would imagen. thanks again Take care
