300 wiring diogram
gary j
02-24-2006 07:34:38
Can any one help me with a 300 row crop farmall wiring diogram.I have manuals,but none of them have a diogram in them.My tractor may have been wired wrong.It will not charge.Regulator and generator are ok.
Janicholson
02-24-2006 12:15:36
 Re: 300 wiring diogram in reply to gary j, 02-24-2006 07:34:38
Do an archive search for Bob M wiring diagrams, they work.
JimN
Andy Vink
02-24-2006 08:36:20
Courtesey of Farmall-H.com this is the recomendation for repolarizing a generator. I don't have any diagrams available to suit your need but maybe this will be of some help.
Repolarizing Your Generator
If your tractor has been stored without a battery for a while, or generally has charging problems, you may need to repolarize your generator. You need to do this anytime the generator or regulator has been removed or the leads disconnected. This is a really easy procedure, and requires only a short piece of wire. First, make sure that the positive terminal of the battery is grounded. Then, momentarily connect a jumper between the "BAT" terminal of the regulator and the "A" terminal of the generator. Hold the wire on one end and just brush it across the other - you should see a spark. If you do see a spark, you're done. It is that easy. Remember, don't connect the wire, just momentarily touch it. And make sure you have the right terminals at both ends (they should be labeled). If you do the wrong ones you're likely to fry your regulator.
