Re: Furrow Wheel - 311 Plow
Farmall Frank
02-24-2006 13:22:59
Thanks, Hugh. I cleaned up the unit, pounded out the pin, and it all came apart. Some of the numbers are: 521155R1, 521156R1, 521165R1, and 521166R2. These are the bearings and hubs, etc.
You are right, these cannot be adjusted.
I would also be interested in the parts diagram for the unit with a rubber wheel, as I just found one that I will get tomorrow. It has real bearings instead of bushings.
Hugh MacKay
02-24-2006 14:51:36
 Re: Furrow Wheel - 311 Plow in reply to Farmall Frank, 02-24-2006 13:22:59
Frank: The inside bearing is part number 521 115 R1. The outside bearing is 521 156 R1. The pin between them is 521 383 R1. Inside box or hub 521 165 R1. Outside box or hub 521 166 R2. Steel wheel pan 522 995 R1. Scrapper for steel wheel is 523 009 R1. The axle for steel wheel is 524 504 R92.
I don't have the technology to send you the diagram. There are two pneumatic rear furrow wheels listed. One is for rigid beam plow, while the other is for the trip beam plow. The actual hub, bearings, seals, wheel and tire are the same for both setups. The only thing different is the mounting and axle arm going to the plow. Looking at this I expect the parts for the trip beam plow will work on either rigid or trip beam plow.
