Super C Block..... replacement?
Ida Red
02-24-2006 19:40:57
Can the block from a regular C be adapted to a Super C and if yes, what changes do you have to make.
Ida Red
02-25-2006 09:50:26
 Re: Super C Block..... replacement? in reply to Ida Red, 02-24-2006 19:40:57
Thanks for the info fellows.Red
El Toro
02-25-2006 04:22:31
The block in the C can be boosted to 123cid with a
new sleeve kit to 3.125" then it would be the same as the Super C block. There's only a couple
of differences in hp. Hal
Handyman
02-24-2006 20:28:30
the only difference in the engines will be the C will probably be a c113 engine and the SC will be c123 engine but they are the same block casting so all the bolt holes will be the same, you will want to put the water pump from the SC engine onto the c engine but it is a direct bolt on part
