ATTEN. K.B.826!!
Erik in WI
02-25-2006 10:10:42
I drained the oil on my 826, and on the plug, it does not have a copper washer, does your 826? Also, the dealer told me I could use a regular oil filter off of a 400 series engine (66 and 86 series tractor), is that what you use? I put one on and it seams to fit, but wiggles a little even when tight. Any information is appriciated.
Thanks Erik in WI
K.B.-826
02-25-2006 19:45:40
 Re: ATTEN. K.B.826!! in reply to Erik in WI, 02-25-2006 10:10:42
Yes, there should be a sealing ring on the drain plug. I'm almost 100% sure that the filters for the 400 series engines have a different thread size. The 310 and 358 German diesels in our 826, 786, 3088, and the 686 we used to have all use the same spin-on filter as our 706 gas. Believe the Case-IH part number is 398080R1.
MN Scott
02-25-2006 10:31:07
My parts book shows a copper washer on the drain plug for an 826 PN. 933609R1. The book shows two filters, one is a short one and the other is longer, more capacity, either will work. pn,3132737R93 and 528250R1.
