Farmall M is it - or+ ground???
Joe Bly
02-25-2006 15:02:31
The farmall M I have did not have a battery in it when I got it. I am putting a new battery in but I am not sure if I should hook it up with positive ground or negative ground. How do you know which way it should be hooked up???
Hermit
02-25-2006 17:57:24
 Re: Farmall M is it - or+ ground??? in reply to Joe Bly, 02-25-2006 15:02:31
If the rest of the wiring system is set up correctly, look at the coil. If the wire to the distributor is connected to the - post then it's a negative ground. If the wire to the distributor is connected to the + post, then it's a positive ground.
Joe Bly
02-25-2006 16:32:21
It is 12 V but it is a older Generator not an alternator
El Toro
02-25-2006 16:45:20
 Re: Farmall M is it - or+ ground??? in reply to Joe Bly, 02-25-2006 16:32:21
Take a look at the old battery cables to see which
cable one is the ground cable. Should be connected to tractor frame. There's a difference in the hole size for connecting your battery cables to the battery. The cable with the larger hole is for the positive terminal. If
your ground cable has the larger hole your tractor is still using + positive ground. Hal
Joe Bly
02-25-2006 16:51:58
 Re: Farmall M is it - or+ ground??? in reply to El Toro, 02-25-2006 16:45:20
unfortuntley both battery cables are black neg. cables so no help there
El Toro
02-25-2006 19:08:42
 Re: Farmall M is it - or+ ground??? in reply to Joe Bly, 02-25-2006 16:51:58
If the tractor has battery ignition look to see
where the wire that is connected on the coil that
goes to the distributor. If your tractor's battery is + grounded, the + terminal on the coil
goes to the distributor. If it uses a negative
ground on the battery, the - negative terminal on the coil goes to the distributor. Hal
El Toro
02-25-2006 16:29:49
If it's still 6 volt it's + ground and if it has
been converted to 12 volts with an alternator it should be negative - ground. Hal
Tom Windsor
02-25-2006 16:20:36
Tom Windsor
02-25-2006 16:39:34
 Re: Farmall M is it - or+ ground??? correction in reply to Tom Windsor, 02-25-2006 16:20:36
if it is origial 6 then "+" but if it is converted to 12, I dont know.
