IH Carb Adjustment
IronHorse
02-26-2006 08:37:58
I have a U-240 Power unit the carb looks like the ones on the M's I've seen has the tube between the gov and carb. My question is the idle adjust screw works best if it is maybe 1/4 turn off from the seated position. is this rite if I back it out any more the engine misses and sound bad. if it should be back out more where do i look to correct the problem.
as always that for the great help
CNKS
02-26-2006 11:08:58
 Re: IH Carb Adjustment in reply to IronHorse, 02-26-2006 08:37:58
If you are happy with the performance and the exhaust pipe and plugs are clean, leave it alone. At least you get some response when you change the setting, a lot don't.
Wayne Swenson
02-26-2006 10:20:06
Has the carb been cleaned?
Is the air cleaner serviced?
Check the basics first and be sure the ignition timing & spark quality are correct; ignition problems sometimes act like carburetion troubles.
With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1 turn or more beyond the "sweet spot" to be sure the engine isn"t starving for fuel and can develop its rated power.
The same procedure can be followed for idle mixture with the addition of the ldle stop screw to set the low speed RPM.
On the “M” carb, the idle mixture screw is an air adjusting screw so turning in will richen the mixture and out will lean the mixture.
Aren"t carbs fun!!
RustyFarmall
02-26-2006 10:15:02
The idle adjustment screw should be set where the engine runs the best. If that is only 1/4 turn out, then so be it. Leave it there.
