Super H engine overhaul 1953
Jerry D
02-26-2006 13:38:30
I am looking for some specs so I can put my engine together, maybe someone can help?
Ring gap
rod cap clearance
Torque specs for rod capand head bolts
Valve clearance
El Toro
02-27-2006 05:07:30
 Re: Super H engine overhaul 1953 in reply to Jerry D, 02-26-2006 13:38:30
Ring gap is .007-.017", rods .002-.003" I think
this is too much should be .001-.015" for good oil pressure. New cam bearings determine good oil pressure too. Rod torque is 40 ft-lb. Head is 70 ft-lb. Valve clearance is .017" hot so set them at .020" cold. Hal
PS: Mains at 75 ft-lb
the tractor vet
02-26-2006 14:58:55
Spend 30 bucks for a IT manual everything you wanted to know is in there .
Jerry D
02-27-2006 04:10:49
 Re: Super H engine overhaul 1953 in reply to the tractor vet, 02-26-2006 14:58:55
I ordered the book last week and two weeks out
