D460
farmalman
02-26-2006 17:16:31
eng rebuilt,timed,smokes but doesn't runany help
#1ihdoctor
02-27-2006 17:35:14
 Re: D460 in reply to farmalman, 02-26-2006 17:16:31
If you had the injection pump off, make sure you didn't get it 180 deg. out of time. The pump will only go on two ways & it might be wrong. Turn the engine over till it on #1 firing stroke & TDC then line up your marks on the pump. Good luck.
jossette
02-26-2006 17:46:25
crack the fuel lines at the injectors and spin it over to get all the air out...
ejr-IA.
02-26-2006 17:36:01
The glow plugs all have to work right to get it to fire.Have you got the fuel system bled all the way to the injectors?Some times I have pulled the tractor around to get enough cranking speed to get them to fire.
