OT OT OT HELP PLEASE
tn terry t
02-26-2006 20:47:04
i have a 2001 dodge ram 2500 with the cummins engine. its throwing a fit wont hardly run sounds like its starving for fuel i changed the fuel filter with no help its throwing a p1693 code. companion engine control fault what the heck does this mean? i need help PLEASE!
gordy from Iowa
02-27-2006 19:53:33
 Re: OT OT OT HELP PLEASE in reply to tn terry t, 02-26-2006 20:47:04
I would agree. You probably need a transfer pump. Put two or them on my '01 and an injection pump also. One transfer pump lasted about 12,000 miles.
caseyc
02-27-2006 08:06:57
according to dodge it's time for a transfer pump update, part #5175538AA for $380.00. they replace the engine mounted one with an intank one. the really bad news is the injection pump usually goes pretty soon after. some guys have figured out a cheaper solution so maybe they'll chime in.
casey in SD
evilboweviel
02-27-2006 07:33:05
check with tractor vet
I believe that your transfer pump is bad and needs replaced. Bouncer on tractor tales could help also
Ron
