Adding Remote Hyd. to 300U
CharleyFarmall
02-27-2006 09:43:55
I have a "56 300 Utility that I want to add a remote to so that I can operate my dump trailer. All I have is the single valve used for the fast hitch - which I use so I don"t want to disable it. Solutions anyone? Anyone have another valve I can stack on??
Thanks
Charley
JLE
02-28-2006 03:47:34
 Re: Adding Remote Hyd. to 300U in reply to CharleyFarmall, 02-27-2006 09:43:55
If you do not have power steering, all you need is a valve, tie bolts, control lever and an end cover. the vave is common between many series of IH tractors
CharleyFarmall
02-27-2006 16:49:28
Yes, it has just the single valve for the hitch. Is the valve common? Any particular name that it is called or do I just ask for an IH valve for a 300U?
Nat 2
02-27-2006 13:07:49
It's odd that a 350 would have no hydraulic remotes, but have a fast hitch. Are you sure?
There should be two controls on the operator's platform, to the right of the seat. If not, they can be added on using stock parts. All you need to do is find them at a tractor salvage yard.
Janicholson
02-27-2006 14:49:52
 Re: Adding Remote Hyd. to 300U in reply to Nat 2, 02-27-2006 13:07:49
Sorry Nat, it is a 300, same problem but possibly more likely not to have the remotes on it.
Your solution is correct though.
JimN
PAULIH300
02-27-2006 14:49:09
Utes were available with no hydraTouch valves,1,2,or 3.The base tractor had none,and no hydraulic pump.If you ordered Fast Hitch you got a pump and one valve.
