300 AIR CLEANER
RICK/OASIS ID
02-27-2006 10:16:31
Is the air cleaner on the 300 a replaceable element or do you buy the whole can and all. I don't see a joint or seam where it seperates and don't want to screw up the can since i assume it's a element inside that comes out. Thanks Rick
Brownie 45
02-27-2006 11:36:03
 Re: 300 AIR CLEANER in reply to RICK/OASIS ID, 02-27-2006 10:16:31
The stock air cleaner is an oil bath type unit. Take the bottom cup off by loosening the clamping band which holds the top & bottom sections together. Emty the oil into a container & check for dirt or other debris in the bottom of the cup. Use a table knife to dig out dirt which has accumulated in the cup. Refill with engine oil to the level designated on the side of the cup after cleaning.
RICK/OASIS IDAHO
02-28-2006 13:50:16
 Re: 300 AIR CLEANER in reply to Brownie 45, 02-27-2006 11:36:03
Sorry for the delayed response my P/C wouldn't load the web page for some reason, any way i have done that and the filter is really gunked up so i was curious if it (the filter) is replacable or do you have to get a whole new can or is there a proper cleaning method/ product to use so as not to screw up the filter
Janicholson
02-28-2006 14:11:34
 Re: 300 AIR CLEANER in reply to RICK/OASIS IDAHO, 02-28-2006 13:50:16
The mesh material in the top part is not removable.
Taking the entire cleaner off, and rinsing it with solvent will clean it well. It does not need to be spotless, if the sludge in the pan is cleaned out, and new engine oil filled to line, you are good to go.
JimN
