Farmall 350 Front Loader?
Ken(IL)
02-27-2006 12:04:33
Will a front loader that fits a 460 Utility fit a 350 row crop? Been in the market for a fully hydraulic loader and stumbled on this one. Just dont know if it is feasable. I assume I would have to look for a PTO Hydraulic Pump but willing to do it if it will fit. I appreciate any help. Thanks
Ken(IL)
Nat 2
02-27-2006 13:04:31
 Re: Farmall 350 Front Loader? in reply to Ken(IL), 02-27-2006 12:04:33
Got a welder and a torch? It's not a bolt-on affair, but I'm sure it could be modified to fit.
Your 350 should already have at least two hydraulic remotes, plumbed exactly where you'd need them to hook up a loader with hydraulic tilt bucket (up under the gas tank). Unless you're looking for super-fast cycle times, and you're going to use the loader a LOT (in which case you should be getting a skid steer or dedicated loader tractor anyway) you shouldn't need a PTO-driven pump. The built-in live pump should be just fine.
Bencie
02-27-2006 16:00:11
 Re: Farmall 350 Front Loader? in reply to Nat 2, 02-27-2006 13:04:31
Ken, I took a loader off of a 560 rowcrop and put it on a 300 rowcrop. The only thing I had to make were 1 inch spacers where it bolted to the bellhousing. The 300 was 2 inches narrower than the 560. The 460 is the same width as the 560 I think. The hyd. pump works everything just fine. The loader is an IH 1701.
