DISTRIBUTOR PROBLEMS
FRED AUSTIN
02-27-2006 13:14:05
I HAVE A 1950? CUB, WHEN I PURCHASED IT IT WAS NEEDING WIRES A COMPLETE TUNE UP, NOW IT WONT RUN UNLESS THE COIL WIRE IS PULLED ABOUT 1/8 INCH FROM THE DIST CAP... WHAT DO I DO TO FIX THIS?
El Toro
02-27-2006 15:05:48
 Re: DISTRIBUTOR PROBLEMS in reply to FRED AUSTIN, 02-27-2006 13:14:05
Are your plug wires copper wires? Hal
Janicholson
02-27-2006 13:38:00
The plugs are fouled from either too rich a mix/use of choke, or oil burning. You do not say what has been done. Pulling the wire increases the spark voltage to about 10 thousand or more which blasts through the crud and ignites the fuel dispite the fouling. Clean the plugs and fix the cause of the fouling.
JimN
