1066 3 point control lever adjustment
Michael Sheik
02-28-2006 05:37:10
When using my 1066 in the field the control lever that raises/lowers the 3 point arms creeps forward and allows the arms to lower. You can reach down and move lever to raise position and arms come up nicely BUT if you look down there in 3 or 4 minutes the lever is back in the forward (lowered) position. There is almost no resistance on the lever when it is moved up or down and I would think there should be some. Is there a friction disk adjustment on this lever that will hold it in position better. If so please explain how to as my IT manual is not doing a very good job here. I would note that I have cab and a little hard to see down there.
IaGary
02-28-2006 06:39:09
 Re: 1066 3 point control lever adjustment in reply to Michael Sheik, 02-28-2006 05:37:10
If you look under the platform from the rear you will see the bottom of the levers on a pivot point.
Reaching with a socket and an extension you can tighten the lever pivot point.
It doesn't take much tighting to cause more friction.
Good luck
Michael Sheik
02-28-2006 12:58:39
 Re: 1066 3 point control lever adjustment in reply to IaGary, 02-28-2006 06:39:09
Thanks Gary
I'll break out the flashlight and try tonight.
