Glass precleaners Which jar to use?
red guy
02-28-2006 06:44:46
I am looking for glass jar precleaner for my farmall M. I have found a few but they all have different jars. Which is correct, the square Ball jar or the square Kerr jar? Thanks for the info.
BillyinStoughton
03-01-2006 08:07:15
 Re: Glass precleaners Which jar to use? in reply to red guy, 02-28-2006 06:44:46
In my previous post I stated that the correct jar was a Ball Special with four vertical bars at the corners...not quite right on that one. It has six vertical bars (two on each side that are opposite the "Ball Special" label. RustyFarmall has it right on the size though...I looked at the original on my 52 H last night.
Billy
baler 46
03-01-2006 04:11:15
Hi i sawthose jars in hobby loppy theother day do not rember the name on them those.
BillyinStoughton
02-28-2006 06:53:34
It"s the Ball "Special" that originally came with the pre-cleaner. The correct jar will also have four vertical bars at the corners...not all Ball jars will have these. I"m not sure what is the correct size, but with all the knowledge on this sight, i"m sure the answer is coming.
Billy
RustyFarmall
02-28-2006 08:44:31
 Re: Glass precleaners Which jar to use? in reply to BillyinStoughton, 02-28-2006 06:53:34
You are correct, Ball Special, one pint, wide mouth. Those jars are getting scarce, which is why you see so many different jars. If you are a stickler for original, you need the Ball special. If you just want a jar, any wide mouth canning jar will work. I have even see the one quart size on a few Ms.
