Farmall H radiator cap
phillip womble
02-28-2006 15:58:49
Bought a 1946 H yesterday. It came with a pressure type radiator cap, and I need to ask the experts whether that type cap is correct for my tractor?
Nebraska Cowman
02-28-2006 16:29:04
 Re: Farmall H radiator cap in reply to phillip womble, 02-28-2006 15:58:49
It realy don't matter cuz the pressure cap won't fit a non-pressure radiator. Any radiator upgrade over the years would be to the newer pressure type. The advatage is that water boils at a higher temp under pressure so less coolant loss.
Andrew Z
02-28-2006 16:18:57
Yes it should have a pressure cap. Make sure and check the pressue on the cap, I think the original ones are like 6 or 7lbs. Only the early ones had a no pressrized system. Andrew
