Farmall 560 help
Big Red M 46
02-28-2006 19:32:51
I just replaced the TA in my 560 checked the engine cluth and pressure plate and they looked great. I did have the flywheel turned at a local machine shop. When I started the tractor I noticed that the clutch is grabbing and when runnig I cannot get the tractor into gear. Although when I step on the brakes it does not bog the engine down. The clutch rod is all the way out.Any ideas?
El Toro
03-01-2006 02:58:42
 Re: Farmall 560 help in reply to Big Red M 46, 02-28-2006 19:32:51
I don't think you have the clutch adjusted with enough freeplay. Sounds like the clutch isn't disengaging since you can not engage the gear shift. Hal
Big Red M 46
03-01-2006 08:31:59
 Re: Farmall 560 help in reply to El Toro, 03-01-2006 02:58:42
I am going to try and readjust everything again tonight. Thanks for the input I will keep trying until I get it right.
Big Red M 46
03-01-2006 18:58:19
 Re: Farmall 560 help in reply to Big Red M 46, 03-01-2006 08:31:59
Okay, I readjusted everything according to the manual.I still have the same problem. Is is possiable that I have the throw out bearing in wrong or something like that? I really do not want to but it looks like I am going to have to split the tractor again Uggh!!!!! !!!!
Oregonfarmer
02-28-2006 21:40:36
Did you adjust the clutch and TA linkage according to the specs in your manual?
John Adamson
02-28-2006 19:47:34
did you put the clutch disc in backwards?
That is what it sounds like.
Big Red M 46
02-28-2006 20:00:30
 Re: Farmall 560 help in reply to John Adamson, 02-28-2006 19:47:34
I do not think so, It would only fit one way. it hit the other way. Iput it with the hub out towards the pressure plate.
