fast hitch for Super MTA
OZ
02-28-2006 22:27:20
Can anybody tell me if all MTA's were built to accept a fast hitch, or was this a special option?
Also, what fast hiches are interchangeable with the MTA? 400,450,560?
Thanks OZ
Nat 2
03-01-2006 05:22:01
 Re: fast hitch for Super MTA in reply to OZ, 02-28-2006 22:27:20
I believe the rear end casting is the same as the 400's rear end casting. Only the 400 fast hitch will fit.
Hugh MacKay
03-01-2006 05:32:41
 Re: fast hitch for Super MTA in reply to Nat 2, 03-01-2006 05:22:01
Nat: I know what your saying sounds reasonable, however you have it backwards. Just the 450 and 560 hitches will fit an MTA. If you can figure out why IH did it that way, your one H@## of a smart man.
FM
03-01-2006 10:49:20
 Re: fast hitch for Super MTA in reply to Hugh MacKay, 03-01-2006 05:32:41
I thought that if you changed the top cover a 400 FH would fit on an MTA?? They probably did it that way to sell tractors instead of fast hitches:-)
Mike
Hugh MacKay
03-01-2006 19:51:30
 Re: fast hitch for Super MTA in reply to FM, 03-01-2006 10:49:20
Mike: Your right, there in lies the answer. My thinking is fast hitch was in the engineering stage before either MTA or 400. Looks to me like IH felt they didn't have draft control perfected to a point they would put in on the market, thus the 300-400 hitch was modified giving depth control only. Why it was necessary to change that top cover, who knows.
