Hydraulic leak from differential lock on a IH-424
bbwhite1
03-01-2006 06:00:41
How many seals are there around the differential lock shaft that comes out of the side of the tractor?
What about the shafts for the brakes? Has anyone ever replaced these seals?
Thanks.
BWhite
bbwhite1
03-06-2006 10:05:49
 Re: Hydraulic leak from differential lock on a IH- in reply to bbwhite1, 03-01-2006 06:00:41
Tim,
I replaced the seal on the differential lock shaft over the week-end. You push back the metal sleeve surrounding the shaft and block it in place with a dowel, piece of wood, bolt etc.
Remove the snap ring on shaft and then the dowel. The sleeve will come off. There's an o-ring on sleeve. That's the only seal for my differential lock. I screwed up the snap ring on mine so I've got to get another one.
I'm not sure if you can remove the diffential housing, slide it over the shaft and replace the other gasket and seal or not. Hope this helps.
Tim in New York
03-02-2006 20:14:22
Good questions. I've got the same problem on my 2424 and was wondering the same things. Lets hope someone out there answers.
Tim in New York
