Hydraulic Filter on 826
Jim Allen
03-01-2006 06:03:52
Silly newbie question here. I recently replaced the hydraulic filter on my 826 and now notice that the cover is dripping a bit. It's the type with two bolts and an o-ring. I probably rolled the o-ring or something... and yes I did lube it! Anyway, If I remove the cover to repair this leak will ALL the oil drain out of reservoir, or just what's in the filter area? I didn't pay enough attention when I was doing it 6 months ago and now don't remember. Many thanks!
Jim Allen
03-01-2006 06:44:48
 Re: Hydraulic Filter on 826 in reply to Jim Allen, 03-01-2006 06:03:52
Thanks Tractor Vet! Better to know in advance than trying to stem a 20 gallon tide of gushing hydraulic fluid. I still have an unopened six gallon bucket of THF, and a new o-ring, so I'm set.
Michael Sheik
03-01-2006 06:28:31
Does this apply to a 1066 hyd filter also that is on right side under cab. Been wanting to do this as bought used and not knowing when changed last. Only reason I have not done is that I figured all hyd/rearend oil would drain when I did. If not, I will get IH filter and do.
the tractor vet
03-01-2006 06:34:59
 Re: Hydraulic Filter on 826 in reply to Michael Sheik, 03-01-2006 06:28:31
All that will come out of the filter will be about a gallon and a half to two gallion. and one thing that i have found over the years is that the square cut O/Ring is missing on the tin back plate that most guys do not know that there is suppose to be one on it and when changing the hdy filter on ALL the tractors always replace the Gskt. on the ones that you have to remove the whole cover and on the ones that just have the cap and the two wing nuts always replace the O/Ring as it gets hard and does not seal and if it leaks then it is sucking air even though your hdy's may work it is still sucking air.
Michael Sheik
03-01-2006 06:39:40
 Re: Hydraulic Filter on 826 in reply to the tractor vet, 03-01-2006 06:34:59
Yea! Mine has the wing nuts
IaGary
03-01-2006 06:14:36
Just whats in the filter cavity will leak out.
