Farmall C vs. Super C
Al Wolka
03-01-2006 06:11:30
I recently purchased a Farmall with the sticker indicating Super C. However, the info at the clutch is this: 2.10.T, which I think tells me that the tractor was built October 2, 1950. Publications tell me that the Super C was not built until 1951. SO! What do I have? Was the tractor modified in the last 55 years to upgrade from an original C to a Super C? Or was it an early model Super C?
Al Wolka, 4245 So.Co.Rd. 460W, Vallonia, IN
gene bender
03-01-2006 19:12:34
 Re: Farmall C vs. Super C in reply to Al Wolka, 03-01-2006 06:11:30
Check serial# behind throttle rod under #1 spark plug.
CNKS
03-01-2006 11:19:01
2*10*T means that part was cast Feb 10, 1950. not the other way around. Originally white C's had (we think) serials from 47010 through 54411, you might check yours. To certain people they are valuable, at least they think they are. Look at your clutch and brake pedals, if straight you have a C, if curved, a Super C. Although parts, even engines and sheet metal (Super C has a taller grille) can be replaced, there really is not an "upgrade" to a Super C. Defining factor is the serial number.
Al Wolka
03-01-2006 13:08:21
 Re: Farmall C vs. Super C in reply to CNKS, 03-01-2006 11:19:01
Now I need help finding the tractor"s serial number, but first of all, thanks to all who responded. You have been very helpful, as this is my first venture into antique tractors.
Where is the serial numbere on a Farmall C?
Al Wolka
Al Wolka
03-01-2006 13:06:36
Al Wolka
Al Wolka
03-01-2006 13:06:02
Al Wolka
Wayne Swenson
03-01-2006 13:33:49
 Re: Farmall C vs. Super C in reply to Al Wolka, 03-01-2006 13:06:02
Serial number is on the right side of the seat tool box.
Guy Fay
03-01-2006 10:58:37
The casting codes do not indicate when a tractor was assembled. They indicate when a part was cast. Thre can be considerable difference.
What is the serial number on the tractor?
El Toro
03-01-2006 06:23:54
You can tell from the serial number. If the SN contains 6 numbers it's a Super C. They started at sn 100001. They have disc brakes too. Hal
gene bender
03-01-2006 06:23:41
Just another case of wrong decals.
