Trans TA fill Hole
Larry Hough
03-01-2006 09:49:44
Would somebody please tell me where the fill hole for a Farmall 400 with TA is.I know where the plugs are to see if it low. BUT WHERE DO YOU PUT THE OIL IN AT!! The Local dealer (CaseIH) could not tell me either. Thanks Larry
f20king
03-01-2006 09:59:18
 Re: Trans TA fill Hole in reply to Larry Hough, 03-01-2006 09:49:44
there is a small plate with 3 bolts in it by the shifter lever. You can pour oil in there.
Larry Hough
03-01-2006 10:07:50
 Re: Trans TA fill Hole in reply to f20king, 03-01-2006 09:59:18
Thanks I thought that might be it but the Dealer said that was to check the gears.HA_HA I quess I should use HY_Tran fluid and It will go to the TA too!! Thanks Again Larry
Nebraska Cowman
03-01-2006 10:15:32
 Re: Trans TA fill Hole in reply to Larry Hough, 03-01-2006 10:07:50
oh there's a whole generation that's growed up never seeing the inside of a tractor built before 1960. But that's OK; don't ask me nothin' about the newer stuff.
the tractor vet
03-01-2006 11:19:54
 Re: Trans TA fill Hole in reply to Nebraska Cowman, 03-01-2006 10:15:32
About like me after ya get past the 86 seires , good thing that all us poor farmers around here farm with the old stuff .
