Farmall H serial number
Chuck A.
03-01-2006 12:26:08
I have a farmall h and the serial number is 501. I've looked up the years that they made them and found that in 1939 they started with the number 501. My question is; did they start with 501 from every factory, or is this the fist one ever built? If anyone has any info on this, I would like to here from you. Thanks, Chuck
MJ in the UK
03-02-2006 04:52:54
 Re: Farmall H serial number in reply to Chuck A., 03-01-2006 12:26:08
I have seen over here in the UK a W4 tractor supplied on the lease lend scheme in 1940 with the serial number 504. It has been on the same farm from new and the serial number plate is all ok MJ
gene bender
03-02-2006 01:19:22
You better get plenty of insurance and keep tractor in safe place cause it would bring probably 20,000 or more just make sure that the serial# is true and not fake. Does the hood fasten on with hex head with a slott for a screwdriver. Check the casting codes what do they say?
MJF
03-01-2006 19:57:53
Wouldn't that have stayed in the IH factory or a IH museum. I can't hardly believe that that tractor would have slipped out but hey anythings possible. If it's true your sitting on a gold mine and your a very lucky man. Do you know any history on it.
sammy the RED
03-01-2006 15:15:31
I think he is playing us.
If it is 501, should be worth some Big Bucks !
Nebraska Cowman
03-01-2006 14:47:25
Oh WOW!!!!! !! That would sure beat the soldier boy's Corvette story. If you are reading it correctly that IS the first H produced!!!!! !!!! Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes !!!!! !!!I am all excited now. Every collectors dream to find something like that! I have a picture of the first 4640 John Deere but who cares about that? I'm an IH man.
Wayne Swenson
03-01-2006 13:24:24
Can you take a picture & share with us?
Nat 2
03-01-2006 12:54:17
I believe they only made Farmalls in one factory, the Farmall factory, up until the early 1950s. IF, and this is a big if, that is an original serial number, you would be the owner of the first production H.
Dave_Id
03-01-2006 13:04:49
 Re: Farmall H serial number in reply to Nat 2, 03-01-2006 12:54:17
Does the engine serial number match? If so, you are one lucky Jose'
Dave_Id
03-01-2006 14:05:52
 Re: Farmall H serial number in reply to Dave_Id, 03-01-2006 13:04:49
Maybe you can build a shrine, and charge guys to come and look at it.. where are you located?
