FARMALL 200
SALLY
03-01-2006 17:03:55
I STARTED MY 200 TODAY AND WHILE DRIVING IT SOMETHING STARTED MAKEING A THUMPING NOISE INSIDE CLUTCH AREA.CLUTCH WORKS FINE.ANY IDEALS WITHOUT SPLITTING TRACTOR.
Hugh MacKay
03-01-2006 22:32:40
 Re: FARMALL 200 in reply to SALLY, 03-01-2006 17:03:55
Sally: Wayne is probably correct if every thing is working ok. The mice love that spot in the torque tube between engine and transmission. Last year I left an old sofa cushion on my tractor seat. I think the mouse lugged 10% of that into the torque tube for his nest. Two places to look are the inspection hole by the clutch and also back where torque tube joins the transmission.
I find the best way to keep them out of there is spray some WD-40 in there ocasionally, or make covers for both holes.
Harold Hubbard
03-02-2006 05:11:40
 Re: FARMALL 200 in reply to Hugh MacKay, 03-01-2006 22:32:40
I always thought those mice were standard equipment on the C, Super C, etc. They are supposed to pedal on the driveshft to give the tractor a little more power.
Wayne Swenson
03-01-2006 20:51:03
Maybe a mouse built a nest & is causing a flywheel balance problem?
Take the oval inspection cover off the bottom of the bell housing (clutch area)& inspect!
