Order Farmall Cub Parts Online
cub carb adjustment
chris8n
03-01-2006 19:46:12
anybody know what the carb adjustment are on a 1952 cub. i just bought it last weekend and am trying to get it running. thanks chris
chris8n
03-04-2006 21:11:23
 Re: cub carb adjustment in reply to chris8n, 03-01-2006 19:46:12
i havent rebuilt it yet i just took it apart and cleaned it up. i am going to rebuild it eventually i am just trying to get it running to make sure everything works. does anyone know by chance if there is supposed to be a expansion plug in the front of the steering box. it looks like there is supposed to be one but i cant tell for sure. this is the first tractor that i bought that might have a mag in it. is there an easy way to tell the differance. i have seen a tag yet but havent looked that hard. thanks chris
chris8n
03-04-2006 18:19:20
it has a ih carb on it and i want to adjust the idle mixture since i cant adjust the main mixture. thanks chris
old
03-01-2006 20:52:44
To start with 3/4 out for idle and 1-1/2 for main and then go from there
Bus Driver
03-02-2006 15:47:54
 Re: cub carb adjustment in reply to old, 03-01-2006 20:52:44
The Cub IH carburetor has a non-adjustable main jet. Most Cubs were equipped with the IH carburetor.
old
03-02-2006 17:14:50
 Re: cub carb adjustment in reply to Bus Driver, 03-02-2006 15:47:54
I knew some did and some didn't just not which where the after market type. But that adjustment works for alomst all carbs when you have just rebuilt one
