1066 News to Tractor Vet etal
Michael Sheik
03-02-2006 08:21:27
Called the IH dealer parts man on getting all the parts I needed and see how bad I would be set back for new brake piston. New piston is 145.18 but here is the GOOD news. He says he has 3 insulators in stock. Price 8.00!!! I am headed up to get one along with all the other parts this evening and cost for everything I need at this point is 245.00. This includes seal, 3 o-rings, inner and outer friction discs and insulator. The shop mechanic that I know real well says he will look at the primary and secondary plates to see if wore too bad but he feels 3/32 probably not bad enough to replace. The man upstairs must be looking over my shoulder today!!!
As far as adhesive for insulator I am going to use 3M Super Trim adhesive and that is pretty sticky stuff.
the tractor vet
03-02-2006 08:34:38
 Re: 1066 News to Tractor Vet etal in reply to Michael Sheik, 03-02-2006 08:21:27
Yea 3M is sticky put has no holding power and it will come off as there is movment that is why the other one came off .
Michael Sheik
03-02-2006 08:44:22
 Re: 1066 News to Tractor Vet etal in reply to the tractor vet, 03-02-2006 08:34:38
I'll ask IH mechanic what to use and maybe they have some I can buy.
Nat 2
03-02-2006 12:35:03
 Re: 1066 News to Tractor Vet etal in reply to Michael Sheik, 03-02-2006 08:44:22
I'll repeat what was said before: EPOXY.
Go to Wal-Mart, in the painting section, next to the masking tape and caulking. There you will find all sorts of glues, including Devcon 2-Ton and Devcon 5-Minute epoxy. Get the 2-Ton stuff, and follow the directions.
Spray adhesive is for applying decals.
the tractor vet
03-02-2006 14:00:57
 Re: 1066 News to Tractor Vet etal in reply to Nat 2, 03-02-2006 12:35:03
The stuff that i get off Billy has a 3-5 second work window once to apply pressure to it and not affected buy heat up to 1500 degrees just don't get it on your fingers and never never use a cotton rag for clean up instant fire ball.
Michael Sheik
03-02-2006 12:45:56
Thanks - Finally a name I can look for!!!
