more horse power with farmall?
daniel gillegpi
03-02-2006 15:29:29
I got a question. I have all ways been told that to get more horsepower you need more cold dense air and more fuel. On the farmall H & M the manifold serves booth as the intake and exhaust. The air is drawn into the cylinders through the carb and past the hot manifold creating hot air. Is it possible to run like headers on them for the exhaust maybe pick up coupple of horespower, replace the oil bath cleaner with K&N filter??
champspa
03-03-2006 14:20:26
 Re: more horse power with farmall? in reply to daniel gillegpie, 03-02-2006 15:29:29
do like Chad says but leave a thin line of cast or number 2and3 will run real rich.
ChadS
03-03-2006 07:31:51
The Denny header dont work well in low rpm engines, they may help a 3500+rpm engine breathe more, but they usually screw up a stock engine. Just too much manifold for the cubic inch. Most, just cut the casting away from the intake and lose heat, thats about the most cost effective way to do it, if your good with a hand grinder, wont take long to remove that iron. if the carb cfms are set up correctly, that air naturally cools thru the venturi. Most of them that sweat around the carb flanges on a 90 degree day are very close to being right. You can run a cooler burning fuel, like Ethanol to help cool the mixture down, and run a long air cleaner tube with the filter on the end to the carb inlet. that will help keep air cooler. visit www.thetractorshop.com for more information. or email me. ChadS
daniel gillespie
03-03-2006 06:31:06
what other dodads could I add to get the most of my tractor foe pulling. I've been told the K&N filter is the best horespoer gin over the stock oil bath.
FatRedneck
03-03-2006 05:26:37
go to denny's carb shop online or call and get a catalog, they offer a two piece header set for an M-450 that i know'll give ya a couple of hp.
FatRedneck
03-03-2006 05:38:18
 Re: more horse power with farmall? in reply to FatRedneck, 03-03-2006 05:26:37
heres the site
ejr-IA.
03-02-2006 16:30:10
Sure! ask on the pulling forum where to buy them.
supermpuller
03-02-2006 18:19:08
 Re: more horse power with farmall? in reply to ejr-IA., 03-02-2006 16:30:10
Get a LP. intake and exhaust manifold, or get hold of Hank Steel in Mich. Its legal to run these set-ups in most pulls headers are a no-no.
riverbend
03-02-2006 18:41:59
 Re: more horse power with farmall? in reply to supermpuller, 03-02-2006 18:19:08
What kind of power do the seperate manifolds make ? A couple HP would be a 7-10% increase depending on where you start.
