Wheel with 4 - 3.5 Bolt Pattern
Farmall Frank
03-03-2006 10:30:10
Are there any wheels available that have 4 bolts and 3.5" spacing between bolts?
Trying to put a rubber tire/wheel on my plow.
gene bender
03-04-2006 03:52:21
 Re: Wheel with 4 - 3.5 Bolt Pattern in reply to Farmall Frank, 03-03-2006 10:30:10
what kind of plow are you putting the rubber on?
Farmall Frank
03-04-2006 05:34:53
 Re: Wheel with 4 - 3.5 Bolt Pattern in reply to gene bender, 03-04-2006 03:52:21
311. I got two of 'em and am trying to restore them to usable. The one has rubber that is hard, and the wheel is rusted through by the air fitting (forgot it's name).
John *.?-!.* cub owner
03-03-2006 19:50:16
I don't have one handy to measure, but that would be close to the 4 bolt New Holland implement wheels.
Janicholson
03-03-2006 14:17:23
The measure is of the bolt circle, not between bolts.
Find a circle (can, lid, object) and be sure of the center diameter (inside edge of all holes plus one hole diameter also works)
JimN
Farmall Frank
03-03-2006 14:10:23
Woops. Didn't measure right. There are 5" between the lugs, measuring diagonally (I guess).
acnky
03-03-2006 13:21:38
golf cart
Janicholson
03-03-2006 12:30:41
Look for automotive wheels on the internet, sort with bolt pattern, then cross to type of vehicle they have cross listed hundreds of sizes.
JimN
