Pictures or Measurements of Fast Hitch Carrier....
migraine
03-03-2006 21:57:42
I would like to redo the homemade fast hitch carrier I have with the large size prongs. It was on a Farmall 300 and has good sturdy frame but was set up to haul 2 55 gallon barrels. I would like to make it to the specs of the original I.H. product. I see some pictures in a few tractor brochures but doesn't give close up shots or any measurements. Would like to have an implement or attachment behind every one of the Farmalls at our show this year and could use this in parades to haul litle cub cadet or pedal tractors. Always dreaming of something aren't I? Any one got some pictures or ideas to share? Migraine
MARK ROBKE
03-04-2006 16:30:19
 Re: Pictures or Measurements of Fast Hitch Carrier in reply to migraine, 03-03-2006 21:57:42
MY DAD HAD ONE OF THESE FOR HIS 300 UTILITY.IT CAME 6'WIDE BY 2'DEEP;HOWEVER,HE SOON MADE IT 4' DEEP.THIS INCREASED IT S USEFULNESS 1000%.I GREW UP USING IT AND AS MY DAD SAID,IT WAS THE HANDIEST TOOL ON THE FARM.IT HAULED EVERYTHING:FENCE,POSTS,HAY BALES,FIREWOOD,CORN FODDER,55 GALLON WATER DRUMS,EVEN COWS(WITH A SPECIAL GATE ATTATCHED).WITH SOME LOADS,IT DID LIGHTEN THE FRONT END OF THE TRATCOR,SO YOU DO HAVE TO BE CAREFUL.
I STILL HAVE IT AND THE 300.FENCING IS MY BIGGEST USE FOR IT.BEING ABLE TO LOAD AT GROUND LEVEL AND RAISING IT UP IS IT S BEST FEATURE.
IT IS MADE AS HUGH MCKAY DESCRIBED.MINE HAS ONLY HAD SOME OF THE LUMBER REPLACED ONCE.
MARK
Tractor Tom
03-04-2006 05:36:05
Here is a site I found with some pics and discussions about build-it-yourself attachments:
Link
I believe I have seen photos there of versions you are looking for. It also includes one of an overloaded carrier that lifted up the front of the tractor, at least it made the steering easier!
Hugh MacKay
03-04-2006 01:51:44
Migraine: I've been around a few of these, never owned one but several of my neighbors did. As I recall most of them came new less the wood, and farmers built the actual platform, which could vary somewhat. I would judge most of the ones I've seen to be 60" to 72" wide and extending back about 36" from hitch point. I have seen the ocasional platform 84" wide.
My dad had a couple of these he built from scratch to fit H and Cub with standard U type drawbars. He used these mainly for putting his can milk out by the road for the truck to pick up. I can tell you two qualities they must have; sized to match the tractor and never build it wider than tractor. The one we had on Cub was too large at 60" wide by 36" deep. 36" just puts weight too far back for a Cub. The one we had on the H was 72" wide and 42" deep, and the H handled that fine as long as the front end loader was on the tractor.
The reason I say don't build it too wide, a lot of folks have turned too quickly after driving through a gate, by a car or pickup, near a fence, etc. If I were building one it would be 6" less than width of tractor.
migraine
03-04-2006 07:43:09
 Re: Pictures or Measurements of Fast Hitch Carrier in reply to Hugh MacKay, 03-04-2006 01:51:44
Thanks so far guys any pictures or literature out there? Migraine
Hugh MacKay
03-04-2006 08:56:03
 Re: Pictures or Measurements of Fast Hitch Carrier in reply to migraine, 03-04-2006 07:43:09
Migraine: If you go to photo adds here at YT about 3-4 days back there is one of these for sale. I think when IH sold these it could be ordered one of two ways, either completely assembled or they sold you the metal hardware kit and you used a local lumber supply. I remember seeing one of these kits at a dealers, it was little more than two fast hitch forks with a step down, much like the mowers have. The forks had cross members tieing the two together. 2" lumber was bolted to that crossways the tractor travel, using the customers desired length of lumber. In essence the customer could make it any width he wished. The kit also contained two pieces of 2x2 angle iron to attach and tie the ends of the boards together. These were just that simple.
The ones my dad built for H and Cub were built much the same principle other than he used 3" or 4" by 6" or 8" over the U drawbar and in the case of the H under the axle carrier, and on the Cub under the cross bar the swinging drawbar hooked to.
As I said before, the one we had for the Cub was too larger for loading. My dad built it that way on purpose, as he used it doing fences. He used to pile posts close to tractor, leaving enough space at back for him to stand on and swing the 16 lb. mall he had. This put him up a bit higher. In our area winter frosts use to heave posts and you had to give them all a few taps with the mall every spring, plus replace a few. When I was about 8-10 dad would get me to drive tractor and he would stand on back pounding each post as we came to it. When we would start in the morning with full load of posts, Cub would be quite light on front. Until we used a few posts off the load, every swing of the mall dad made, you could see front wheel of Cub slightly lift off the ground. Of course with the carrier that long if the front end came up 12" the carrier would skid along the ground.
