656 3 POINT???
Ponchobro
03-04-2006 09:41:49
Hello, i went to use my 656 Farmall and the 3point won't come up. Where should I look???? Thanks for your input!!!
wolfman
03-04-2006 18:44:39
 Re: 656 3 POINT??? in reply to Ponchobro, 03-04-2006 09:41:49
Very first thing to try - tickle the remote control lever & see if hitch raises as it should. (have the hitch lever in up position). My 656 often won't lift its 3-pt til I move the remote lever. I'm not smart enough to know what priority valve isn't...
Allan In NE
03-05-2006 06:35:52
 Re: 656 3 POINT??? in reply to wolfman, 03-04-2006 18:44:39
Wolf, can I help?
Down by your right heel.
This flow regulator block is leaking by and letting the fluid flow thru the remotes to dump instead of charging up the hitch system first.
When you "tickle" that remote lever, it is jigglin' the valve back into action.
Allan
third party image
wolfman
03-05-2006 16:37:02
 Re: 656 3 POINT??? in reply to Allan In NE, 03-05-2006 06:35:52
Thanks Allan. You explained that well. And the photo shows that your tractor is much cleaner than mine. Wolfy.
the tractor vet
03-04-2006 10:05:51
First place is the Hdy filter next does the PTO work , is the hdy oil clear and no water in it , is it below freezeing , There is a start after ya check that out we'll go from there.
