Overhaul steps
Midwest Boy
03-04-2006 11:29:49
I am just about done overhauling an engine, and i was wonder, what all precautions do i need to do to the engine while breaking it in. I know to change the oil, dont bog the motor down... but are there any written rules for best results?
I appreciate any thing go guys answer. Any problem i have you guys are there and thanks.
riverbend
03-04-2006 19:20:40
 Re: Overhaul steps in reply to Midwest Boy, 03-04-2006 11:29:49
The instructions that come with IH pistons and sleeves say to fast idle (3/4 rated rpm), no load until it comes up to operating temperature. Check everything. The next 1/2 hour should be at rated rpm with 1/4 full load. Followed by 1/2 an hour at rated rpm and 1/2 load, 1/2 an hour at 3/4 load, and an hour at full rated load. After that retorque the head and adjust the valves. Avoid over-load, excessive idling, and no load operation for the first 100 hours.
FatRedneck
03-04-2006 12:09:19
if it is a stock overhaul, just take it easy for a while, dont slap the throttle, etc. but if it is built for pullin u should put a two stroke premix for one gallon to five gallons of fuel so you get the rings set properly in the cylinder without burnin em up. good luck!
