M's not starting...
Farm-all-the-way
03-04-2006 12:32:22
Well been busy with a fresh load of baby calves but time to look back to the Farmalls...just had a couple questions about the old M"s
Got one 12V M that has spark to all four spark plugs but it won"t fire for nothing, not sure at all about that....
Another 6V M has power up to the points but that"s it, it doesn"t go any further
Not sure if you guys need any more info but if you do just ask..really appreciate all the help, be nice to see these two girls out running again...THANKS
Josh
Marlin M '51
03-05-2006 03:33:19
 Re: M's not starting... in reply to Farm-all-the-way, 03-04-2006 12:32:22
Make sure you have battery voltage (12 or 6) AT the coil. Low voltage (bad switch) will cause this problem.
Wayne Swenson
03-04-2006 16:25:08
Put some FRESH fuel in first!!
Gasoline gets old in about a month so get rid of the old stuff. Besides, summer gas doesn"t work well in cold temps.
gene bender
03-05-2006 04:33:52
 Re: M's not starting... in reply to Wayne Swenson, 03-04-2006 16:25:08
I havent put any new gas since AUGUST but they all started when i moved some the other day the one was last gassed up in JUNE on the tractor ride.
TomH in PA
03-04-2006 15:13:08
The 12V M might just need points cleaned up or replaced. A spark outside the cylinder doesn't necessarily mean a spark under compression. I'd also check the timing, someone might've mixed up the wires.
El Toro
03-04-2006 14:19:04
You may need new sparkplugs if you have fire at the plugs. Are you sure gas is getting to the
carburetor? This could the problem too.
On the othe tractor with fire at the points. Check for fire at your sparkplugs. No fire at plug wires. You may need a new rotor, cap and plug wires that have copper wire. Hal
MagMan
03-04-2006 13:15:07
Yes Josh I would like to see more info on how you got to where you are. Have they sat for awhile,Just rebuilt,Just became yours??? THANKS JON
Farm-all-the-way
03-04-2006 14:46:02
 Re: M's not starting... in reply to MagMan, 03-04-2006 13:15:07
The 12V M we bought last summer and ran pretty good up til just recently, all four spark plugs have spark but nothing happens, and there is gas getting to the carburetor.
The 6V M hasn"t been running in ten years but all the electrical stuff, meaning the wires, cap, spark plugs, and points were all replaced. Just got a whim one day to try and get it going, but it wouldn"t go either.
Josh
