Two way mounted plow for Farmall H
mhb@ufe
03-05-2006 08:13:04
I have a 1947 Farmall H and it came with a two way plow that apears to mount to the rear axle. It also has a control valve to mount on the light bar to raise and lower the plows separetly or together. I've beeen trying to find a picture or info on this set up. Can anyone point me in the right direction?
Mark
BWNOK
03-05-2006 14:39:37
 Re: Two way mounted plow for Farmall H in reply to mhb@ufe, 03-05-2006 08:13:04
I believe the model in question is a McCormick-Deering Two-Way Tractor Plow No. H-86. My manual does not not show a control valve mounted on the light bar. However it can be raised and lowered via hydraulic cylinders that are plumbed to the belly pump.
mhb@ufe
03-05-2006 15:05:08
 Re: Two way mounted plow for Farmall H in reply to BWNOK, 03-05-2006 14:39:37
When I can get the parts out this spring I will post some pictures. If I remember it Is more like a diverter valve that determines which cylinder would be activated. I will continue searching for pictures. Thank you for your reply. Having a model number will help alot.
Mark
