Super MTA not charging
Retcol
03-05-2006 08:40:16
What is the problem with my voltage regulator? While the tractor is running the ammeter will indicate doischarge. However, when I tap some on the voltage regulator it will then start charging.
the tractor vet
03-05-2006 09:17:04
 Re: Super MTA not charging in reply to Retcol, 03-05-2006 08:40:16
YEa they do that sometimes the points are getting dirty you can clean them with a emery board that the wife uses for here fingernails and i think that is why they mounted it where they did so you can give it a kick with the foot done that many times on mine when ya can kick it to get a charge going then it is time to replace it.
old
03-05-2006 09:08:09
The points in the reg. are probably bad or need to be cleaned. My self I would replace the reg.
