replacing magneto
kazenza
03-05-2006 10:30:18
What is the best way for me to tell if I should replace or rebuild my magneto. I'm about to replace the coil, points, & rotor on my H4 magneto, and I'm wondering with the age of the current unit if it wouldn't be wise to just replace it with a rebuilt unit since I plan to continue to work this machine for a long time. K
NDS
03-05-2006 18:38:08
 Re: replacing magneto in reply to kazenza, 03-05-2006 10:30:18
There are a lot of magneto fans on this forum but I am not one of them. After almost 60 years experience (kids went to work young back in my day) with letter series tractors with both magnetoes and distributors I will take distributor for simplicity, cost of repair and dependability. Back when we were farming with Hs and Ms they usualy ran from 16 to 24 hours a day 6 days a week in tillage seasons and we had better service with distributors. Some say magneto is great because you can start tractor with dead battery but I swore off of hand cranking tractors many years ago. If it were mine I would lose the magneto and install distributor and cost will probaly be less than buying or rebuilding magneto. Just one more opinion.
garyj
03-05-2006 17:48:08
I pulled a distributor off a 350 and put it on my H.It works great.Tractor starts so much faster with the battery ignition.
gene bender
03-05-2006 14:59:59
In the long run the mag will be less trouble. I have some that havent been touched in many years like 20 or so. Two of them run every year in the 3 day tractor ride.
RustyFarmall
03-05-2006 12:50:46
Let this guy help you. His website is not yet complete, but you can contact him from there.
El Toro
03-05-2006 10:42:50
Check the magnets for magnetism. Use a flatblade
screwdriver and touch those magnets. Should feel a strong pull of the magnets. Hal
Sam F.
03-05-2006 10:42:18
How about converting it over to a distributor ?? Have an upright one, vertical after market one, that needs points, condensor, etc. for $85.00 shipped in lower 48. Pictures.
