block
Devin M
03-05-2006 15:02:14
I have a Farmall M with a cracked block. I have a TD6 with a good block i was wondering if i fould take the block out of the TD6 and strip it down and rebuild it with all the parts from my gas M block to to make a good gas block for it?
El Toro
03-05-2006 16:17:39
 Re: block in reply to Devin M, 03-05-2006 15:02:14
Here's a web site for tractor salvage yards. Hal
PS: Some may be in your area and it contains 16 pages.
http://www.epartdirect.com/index.php?t=fc&s=s
FatRedneck
03-05-2006 15:33:13
your best bet is to go to a tractor junkyard and find a good engine that is stuck or what not and tear it down replacing it with your stuff or new.
Janicholson
03-05-2006 15:10:45
The external similarity is cosmetic only, they have no common components or measurements. The diesel has no chance of running like a gasser for making power. The idea is interesting, the nature of the beasts are incompatible.
The TD6 has more value as that (or parted out) than to attempt to make a gasser out of it.
JimN
Bijll Geer
03-05-2006 17:46:55
 Re: block in reply to Janicholson, 03-05-2006 15:10:45
where you at? I got a block out of a M I dont need. Iam in St Johns MI.
