MD Dist . firing order
J. Wilber
03-05-2006 20:20:11
I need to know the distributor firing order on a MD tractor any help would be appreciated.
Haas
03-06-2006 13:16:05
 Re: MD Dist . firing order in reply to J. Wilber, 03-05-2006 20:20:11
Be aware that the rotation of the distributor is counter clockwise as you face the rotor, opposite to the gasoling tractors and opposite to what you would normally expect.
Brad in WI
03-05-2006 21:12:33
that would be 1-3-4-2. just remeber that it turns in the opposite direction of the gas version.
Brad
J. Wilber
03-08-2006 05:34:41
 Re: MD Dist . firing order in reply to Brad in WI, 03-05-2006 21:12:33
That solved my problem , I did not consider the reverse rotation. Thanks a lot
