Farmall M radiator replacement
Chris B.
03-06-2006 11:43:05
Picked up a project M and have been tearing it down for the last couple weeks. Definitely needs a new radiator. Now, the tractor has a bad core with good sheet metal. I just picked up a good used core with bad sheet metal. It appears the sheet metal is soldered/welded to the tanks. Am I right on this? I intend to swap the parts out and make a good radiator.
BTW, I used to post here years ago, but fell out of it. Don't know why, but now I got a new project.
Chris B.
Janicholson
03-06-2006 18:58:01
 Re: Farmall M radiator replacement in reply to Chris B., 03-06-2006 11:43:05
It is very possible to do. If you are a great solderer, no problems, if not have a good radiator shop do it.
JimN
Chris B.
03-07-2006 06:27:00
 Re: Farmall M radiator replacement in reply to Janicholson, 03-06-2006 18:58:01
Well, since I already have the 2 radiators and I'm not out that much I'll give it a whirl. The threads for the mounting studs on the bottom tank are still in good shape, so I think it'll be worth it. May take me a whole day. Near as I can tell, they're both original parts.
Chris B.
bigreddm
03-06-2006 17:07:51
I wouldn"t mess around making 2 into 1 myself. I had radiator problems on my M. I bought a brand new one off E-bay from a guy out of minnesota ( I think. just type in farmall radiator in the E-bay search. It"s buy it now). It was about $250.00. Fits nice even around the steering shaft. While you"re all apart spend the extra and get a new one....
Andy Martin
03-06-2006 14:02:23
If they are identical radiators, yes.
If one is an aftermarket you may have a problem.
ardie
03-07-2006 18:28:29
 Re: Farmall M radiator replacement in reply to Andy Martin, 03-06-2006 14:02:23
I don't know about an M. I bought a replacement for my H and it did not work, luckly the raditor shop still had my original. Got the original rebuilt, about the same money.
