Re: H Oil Pump ?
El Toro
03-07-2006 06:08:09
If the gear shaft has a woodruff key it would carry the load and the roll pin would just retain
the gear on the shaft. I have a parts breakdown
on the Super C oil pump and they use woodruff keys on the drive gear and on the driven gear that is secured with a horse-shoe shaped retaining
ring. The drive gear is secured with a pin. Hal
kfox
03-07-2006 07:55:23
 Re: H Oil Pump ? in reply to El Toro, 03-07-2006 06:08:09
Guess I'd better re-word that last post again. My oil pump drive gear has a woodruff key with a 3/16" retainer pin through the gear & shaft. I can't get the 3/16" pin locally, so I'm using a roll-pin. ken
El Toro
03-07-2006 08:49:57
 Re: H Oil Pump ? in reply to kfox, 03-07-2006 07:55:23
Just make sure the roll pin is a tight fit. Hal
PS: I have a bearkdown on the 504 oil pump too.
It uses a woodruff key in the drive gear and a
1/8 pin. The driven gear must be a pressed fit
on the shaft since no pins or clips are shown. Hal
kfox
03-07-2006 07:50:48
El Toro, Thats the setup I have. I guess my first post wasn't very clear. I can't find a solid pin, so short of using a peened over drill bit stub, I'm going with the roll-pin. Thanks
ken
