IH 826 Torque Spec
Donny
03-07-2006 09:42:55
I am rebuilding the engine in my 826 Diesel and was wondering what to torque the main bearing at? the rod bearing at? and the head at? thanks alot for all your help now and in the past you guy really helped me learn alot. Thanks again
the tractor vet
03-07-2006 10:52:16
 Re: IH 826 Torque Spec in reply to Donny, 03-07-2006 09:42:55
Now lets see here your rebuilding and engine that is a diesel and you don't have a book for the spec's . Well what about sleeve protrushion or stand out have you checked the counter bores?? what about valve ression what about all the stuff that you forgot . I have been building engines since i was a teenager and one thing that i learned form some of the best is ya don't go by memory read the book and all new parts are not the same so ya got six new sleeves that does not mean that the lips are all the same heck i have seen them be thicker and inorder to get them set ya had to cut the counter bore deeper or it was cut to deep so ya had to shim it up . way to much money to waste on a job not done BY THE BOOK . It makes a world of differance on how well the rebuild lasts.
Donny
03-07-2006 20:55:25
 Re: IH 826 Torque Spec in reply to the tractor vet, 03-07-2006 10:52:16
I have the Shop manual I found the main and rod torque but wanted to see what you guys through about it and about the head I am getting new valves put in and also getting it cleaned up. thanks
K.B.-826
03-07-2006 22:40:57
 Re: IH 826 Torque Spec in reply to Donny, 03-07-2006 20:55:25
Definetly go by whatever is in the book.
