Touch Control Oil
Don Mountain
03-07-2006 18:45:27
I have a Farmall Super C, and want to clean out the filter and replace the oil in the hydraulic system. The manual calls for HI Touch Control fluid. Does this have a modern day equal thats more available, or should I go to the HI dealer and ask for it?
Don Mountain
IHC Red
03-08-2006 18:45:00
 Re: Touch Control Oil in reply to Don Mountain, 03-07-2006 18:45:27
It was originally filled with 10w non-detergent. This is still available at farm supply stores.
Personally, this is what I use in my 'C'. If the pump ever leaks (like mine did for a while), it will flow into the engine crank-case. The 10w won't harm your engine. Hydraulic oil could cause excessive engine wear if it gets in there and you run it for a while.
John *.?-!.* cub owner
03-07-2006 19:05:24
touch control oil is now HYTRAN. Your dealer will have it, or you can get a replacement at many oil suppliers, but I prefer the HYTRN myself.
