IH 424 question again
bbwhite1
03-08-2006 06:15:23
While looking for leaks around the break shaft where it comes out of the tractor, I found a hole underneath the part that mounts on housing. This is the part with the shims behind it. The hole looks like it's about the size of a grease fitting hole. Since these are dry brakes and no grease fitting is needed in the area, does anyone have an idea what it is there for? Thanks,
Bob White
bbwhite1
03-08-2006 10:12:48
 Re: IH 424 question again in reply to bbwhite1, 03-08-2006 06:15:23
Just one hole. If it's a weep hole then it could be leaking. I have a lot of fluid coming out in that area. Is it possible that could be the source. Seems like a lot of fluid for a weep hole though.
Thanks,
Bob White
the tractor vet
03-08-2006 06:46:50
Is there just one hole or two or three holes alike ?? if there are two or three then they are for use to pull the carrier if only one then it is probabley a weep hole i have not been into one of them for about 10 years or so so a littel foggy on it .
