Got my new gas caps
HAS
03-08-2006 20:16:47
Well, I ordered my free gas caps last fall and promptly forgot about it. Today I got a package in the mail and wonderd what it could be. Wow, new safety gas caps for my A and H.
DJL
03-09-2006 19:29:38
 Re: Got my new gas caps in reply to HAS, 03-08-2006 20:16:47
I guess I'm one of the lucky ones. I sent in my order form, that someone had provided on this discussion forum about a month and a half back. I listed my M, B, and H on one form. All 3 showed up UPS this past Monday.
Brian Schmidt
03-09-2006 18:38:22
Checked out the online form that someone here listed. Did you guys see the note in the middle of the page?
Note:
After 5/31/2007 you will be able to purchase a replacement gas cap from your local CASE IH® parts distributor.
You think they are finally going to stop giving them away????
thumbanger
03-09-2006 15:34:38
Just ordered mine had six places for serial numbers.
sammy the RED
03-09-2006 10:47:52
I still have all my old gas caps. They work fine.
I could have got new ones back in the 80's when I first heard about it.
I think the replacements are for the small gas caps ?
Rod M.
03-09-2006 06:51:16
about 2 weeks ago I modified the gas cap for my w-4, and it works fine now. ..didn't want gas pissin all over the new paint job. I soldered a short length of 1" copper pipe along with a copper cap on it and drilled a small hole in that. haven't figured how to submit a picture here yet. Was also unaware of the replacements. Rod
BEL@IN
03-09-2006 06:34:11
Received all of mine to. Ordered last fall. Thanks IH.
trw
03-09-2006 05:46:06
I just ordered mine last week sometime. I went to www.ihgascap.com. The form I filled out had line that you could list several tractors. It said wait 6-8 weeks for shipping I believe. I will forget about it too until the UPS man brings it!!!
Slappy
03-09-2006 04:34:55
Mine came as well, but while I asked for two one for my Cub the other for my SA, I only recieved one cap. Should I have put them on separate forms?
HAS
03-09-2006 13:12:33
 Re: Got my new gas caps in reply to Slappy, 03-09-2006 04:34:55
I put both the A and the H on one form and got them both in one box from UPS ground.
Paperwork says they will not fit: F-504 above ser#13400; I 504 above ser#14272; I-606 above ser#6879 and I-2606 above ser#6879.
Also will not fit any of the following tractors: B-275; B-276; I-284; I-354; B-414; I-434; I-544; I-656; and I-2656
Nat 2
03-09-2006 05:02:00
As I recall, the form specifically says, "One serial number per form" or something like that.
HAS
03-09-2006 14:57:42
 Re: Got my new gas caps in reply to Nat 2, 03-09-2006 05:02:00
The form I used had lines where you could enter up to six different tractors and serial numbers. I filled in two, one for my A and one for my H and got them both in one box. That is all I know about it first hand.
FatRedneck
03-09-2006 04:07:49
free gas caps, where?
banjo
03-08-2006 22:07:08
Me too, UPS came driving up and i didn't have a clue what it could be.but once i opened it i remembered.cub and SA
Jack in Ohio
03-09-2006 08:30:21
 Re: Got my new gas caps in reply to banjo, 03-08-2006 22:07:08
I called my IH dealer and asked about the free replacement gas caps and he laughed at me. Told me they quit that years ago. I guess he meant at the dealerships.
