HP JD VS IHC
Jon Blanc
03-09-2006 04:17:55
Just curious: Was a JD 60 about equal to an H or M Farmall? I always figured an H was a two and an M three bottom plow tractor. Thanks Jon
Dr.EVIL
03-09-2006 10:17:50
 Re: HP JD VS IHC in reply to Jon Blanc, 03-09-2006 04:17:55
About the time the Nebraska Test Lab was testing the 60 & Super M's they did a Torque rating on those tractors. They only did that for a couple years, seems like '52, '53, & '54. This supposed TORQUE the old 2-cylinder tractors have sure didn't prove out in the Official Test results I've seen. I've spent Thousands of hours on those old beasts, both red & green and I know that if You lug one of those old 2-cyl. tractors down till You can read the lettering on the flywheel they appear to out-lug a Farmall but the higher torque output of the Farmall, and the torque rise of the engine will prevail, either on the pulling track or getting you thru the tough spot plowing. As far as Pounds/Feet of torque at peak torque engine RPM the Super H actually beat the 60. Maybe those old 2-cyl. deeres didn't like the PTO dyno..... they all hated everything ELSE I ever hooked to the PTO of one of the darned things!
dhermesc
03-09-2006 08:32:04
JD 60 1952-56
42 PTO hp, 321 CI Engine and weighed 5300 pounds
Super M 1952-1954
46 PTO hp, 264 CI Engine and weighed 5139 pounds
Farmall 400
50.78 PTO hp, 268 CI Engine and weighed 5240 pounds
Allan In NE
03-09-2006 04:53:35
Jon,
The 60 is "roughly" the same as a M; just slightly larger with 2 or 3 more HP at the drawbar. Also, it is a little heavier too.
In the real world they both can handle two bottoms.
Allan
FatRedneck
03-09-2006 04:25:16
The JD and the farmall have different types of power, if you mean horsepower, the H is a little shy and the M is a little over a JD 60. the JD has a lot more torque though it will weigh more than the H farmall so you'll be competing with M's not H's unless you lighten it up somehow.
